Windscreen Washer Jet Wiring Diagram
Old Feb 11, 2010 | 01:09 PM
piersleigh's Avatar
Default Windscreen Washer Jet Wiring Diagram
Hi
I own a 2001 Chrysler Grand Voyager and live in London, England. There are not huge number of Chrysler garages in London and my local franchise is not great to be honest. Expensive and a bit unhelpful.
My washer jet has stopped working. I've had it in at a garage and they've traced the fault.
Apparently, the pump is working so they suspected the switch. However, it appears that the problem is not necessarily the switch.
It seems the fault is with the earth signal to the pump. They suspect it is a corroded wire.
However, to trace the wire would require removing the whole wheel-arch cover.
They could definitively trace the problem if they could access a wiring diagram. It seems that Chrysler do not publish this information on the technical information CD-Rom the garage uses.
I am reluctant to go to my local Chrysler garage and have an excellent auto-electrician.
Any leads or diagrams??
Thanks, Piers
Last edited by piersleigh; Feb 12, 2010 at 01:33 AM. Reason: To clarify my location
Old Feb 11, 2010 | 02:59 PM
piersleigh's Avatar
Is there anywhere you can download these online???
Will try the dealer ....
Old Feb 12, 2010 | 01:29 AM
piersleigh's Avatar
If I can find a link to wiring diagram I will definitely post.
F3Speech
Jan 22, 2013 08:05 PM
frinton2011
Mar 19, 2011 03:47 PM
dcm1971
Feb 5, 2010 10:56 AM
lpyle
Oct 31, 2007 01:43 PM
Purbano
Oct 9, 2006 07:49 AM
