WOBBLE
Old Sep 21, 2008 | 07:08 PM
ROMMEL HANNOUCHE's Avatar
Default WOBBLE
I have 1996 Grand Caravan ES that has a wobble in low speeds. It feels like a tire problem but I put 4 new tires on. I put left side axle worked for a while untill I towed a Uhaul trailer. I put another left axle and it is still there. Would worn bearings in transaxle cause the wobble? since I have a leak from the side of transmission. The axles I put on were reman.Someone told me these Caravan had axle problems. Your help is greatly appreciated
Rommel
Old Sep 22, 2008 | 01:01 PM
gareth111278's Avatar
Default RE: WOBBLE
Its worth moving the wheels around the car just to try. but i'd suspect front brake disc [rotor], you can use a DTI to check, but if its bad enough to wobble the wheel its likely to be visibly warped.
are all the suspension bushes good and everything tight? Inc the hub bearing where it mounts to the steering knuckle.
Is the BIG nut on the drive shaft tight & is the washer there?
I know how you feel , i've got 'helicopter' noise on mine, can't find it, i'm gonna do the hubs / bearings next!
Gareth
Old Sep 25, 2008 | 08:13 PM
Default RE: WOBBLE
Thank you for the reply. But I put 4 tires front pads and rotors axles balljoints tight tie rods new stabilizer links bearing hubs tight new swaybar bushings. Would the diff bearings cause the wobble I can't think of anything else.
Rommel
92convert
Other
Sep 2, 2014 09:14 AM
Billste
Aug 18, 2013 04:23 AM
schyllerwade
Aug 4, 2012 11:48 PM
dubs0587
Apr 27, 2010 02:35 PM
