Please Help!!! Thanks
Old Jul 25, 2006 | 02:04 AM
susan's Avatar
Default Please Help!!! Thanks
Hi friends,
My Chrysler cirrus 1995 always has problems during the summer time. Whenever, I drive slowly or stop due to the traffic jam, the " check engine"light is on and the car sounds hardly pick up its speed.
I went to the Canadian tire for computer check-up. It ends up with 3 codes
Code 32 EGR system
Code 33 A/C sensor input hight
Code 51 O2 fuel to air system lean
Can any friend offer me some informations? Thanks a lots
Old Aug 14, 2006 | 01:30 PM
moe's Avatar
moe
Default RE: Please Help!!! Thanks
heres the problem .the egr system which if the car is equipped with a 2.5 engine.is sticking causing the check engine light to come on.it only happens when the weather changes because its cooled down by running anti freeze thru it. this is a common problem and ive done at least 4 of the in my dealership.(dodge)as far as the second code with the ac.its may not be realated.solve the first code and it might take care of at least the third one as well.hope this help full.ps i have to tell you that changing the egr valve is a pain .its located behing the engine below the intake manifold.make sure to change both parts vavle and solenoid.hope this helped moe
Old Nov 11, 2006 | 10:49 PM
greenwoodj2000's Avatar
same, replace the EGR valve AND solenoid both not one or the other, and the rest should take care of itself, and be sure to have the trouble codes erased, or it will continue to display check engine.
seafoamsammie
Apr 15, 2009 12:25 PM
StillAnOptimist
Nov 23, 2008 05:43 AM
strataxe6
Feb 19, 2008 12:34 PM
susan
Cirrus & Breeze
Jul 25, 2006 01:55 AM
susan
