Steering noise '97 Cirrus LXi
Old Nov 27, 2012 | 08:45 AM
Mr C's Avatar
Default Steering noise '97 Cirrus LXi
re 1997 Cirrus 167,000 mi
Just starting hearing a metal grinding noise when the steering hard either left or right. I raised the vehicle for a quick inspection but wasn't able to find any obvious sources. And, I wasn't able to produce the grinding sound when the wheels were off the ground.
There are no other steering or drivability problems.
I plan to recheck today with better light conditions and need some guidance on what to inspect.
Old Dec 26, 2012 | 11:26 PM
Ryan 20's Avatar
Are you still having this problem?
Old Dec 28, 2012 | 11:36 AM
Mr C's Avatar
Yes still have the problem. I'm thinking it's CV joints. Cleaned and inspected the entire front suspension and found no other obvious problems, except for a small tear in the upper ball joint rubber fitting.
Old Dec 28, 2012 | 07:31 PM
Ryan 20's Avatar
Is the steering hard when you hear the metal grinding noise? Or is the grinding noise always there and the steering is easy?
Old Dec 30, 2012 | 10:38 AM
Mr C's Avatar
Yes, steering is easy both left and right. Noise seems to be on passenger side, but it's difficult to judge while diving.
Old Jan 1, 2013 | 02:59 PM
Ryan 20's Avatar
If the noise is not from the power steering pump, I think it could be from the strut or strut bushing. You can try spraying water with a garden hose above the wheel where the strut is and see if that quiets the noise temporarily.
Victor L
Jan 12, 2014 08:38 AM
MyDDBeater
Sep 22, 2009 10:45 AM
Powerlifter626
Feb 14, 2008 01:01 PM
VFRbeliever
Cirrus & Breeze
Oct 29, 2007 11:55 AM
littlebitty
Cirrus & Breeze
Jan 5, 2007 01:54 PM
