Battery drains fast
Old Mar 17, 2021 | 07:57 PM
Rooster4's Avatar
Default Battery drains fast
I could sure use some advice. I have a Chrysler Pacifica, 2004. If I pull all the fuses, I still have a draw of over 12 volts. Help! what else can I do?
Old Mar 17, 2021 | 09:34 PM
Welcome to the forum. You have posted in the "Forum Issues" section of the forum, where people who have experienced issues with the forum itself post up their questions. If you are having an issue with your vehicle, you might get an answer from other owners if they have experienced a similar issue by posting in the relevant vehicle section of the forum. There is a Pacifica section of the forum where Pacifica owners hang out and one might have an answer for you. You might even find that similar problems have already been dealt with there.
Having said that, you should be aware that "draw" is usually a synonym for "current", and is measured in amperes, not volts. If you are measuring volts, you are not measuring a "draw". It would be normal to pull all the fuses and still encounter a voltage of more than 12 volts in the fusebox. That would simply indicate that normal battery voltage is available. To determine the amount of current that is being drawn, you will need an ammeter, sometimes also called an ampmeter.
Old Mar 18, 2021 | 02:49 PM
Rooster4's Avatar
Red face
Thank you. Hope I can find the Pacifica forum.
Old Mar 18, 2021 | 06:43 PM
Just look for "Chrysler Pacifica" in the Chrysler Vehicles section on the front page. Pretty easy.
Rooster4
Mar 17, 2021 07:56 PM
David Hinkle
Dec 15, 2020 09:39 AM
SimmonsHomeRepair
Sep 17, 2020 07:14 PM
dladd@jignet.net
Mar 15, 2007 07:59 PM
