02 T&C Heating issue
Old Mar 25, 2013 | 08:04 AM
02T&CTour's Avatar
Unhappy 02 T&C Heating issue
Hey all
So when I leave the van at idle and not go anywhere it will heat up and needle of the temp goes to middle. almost middle, however I start smelling coolant a little. the hose from the radiator to the thermostat is extremely hard and tight like its about to explode. the radiator is brand new and so is the thermostat. now.. when I drive it (no stop and go traffix, just driving) the temp gauge will go down (at least in this cold weather) and the van wont heat up.. any suggestions?? please help!
Old Mar 25, 2013 | 12:18 PM
its suppose to be in the middle and if u smell coolant get a pressure test done see if there is any leaks
Old Mar 25, 2013 | 01:16 PM
02T&CTour's Avatar
I will get that checked. but why would my hose be extremely hard on press? pressurized like. shouldnt it be able to be squeeze and the coolant just go to the bottle? at least is what im thinking.
Old Mar 25, 2013 | 02:23 PM
IF its after driven no it will have 10-15 lbs of pressure in the system normal it will go in to the over flow when the pressure inside the system is greater then the radiator caps pressure spring.
calmaggi
Mar 30, 2015 10:55 AM
keithm
Nov 8, 2011 06:24 AM
mick1641
19
Sep 18, 2007 12:25 PM
davidandkeiley
May 12, 2006 03:36 PM
chicago_animal
Mar 28, 2006 11:38 AM
