1994 Chrysler Lebaron turns over, but won't start.
Old Aug 8, 2011 | 01:27 PM
jdburns27's Avatar
Angry 1994 Chrysler Lebaron turns over, but won't start.
I have a 1994 Chrysler LeBaron V6 3.0L. I took it apart to replace some parts and now it won't start. The engine turns over just fine, but won't pop. It sounds like it really wants to and every now and then it will pop a little bit but won't run. I replaced the radiator, water pump, water tube, supply/return fuel hoses, intake manifold gaskets, plenum gaskets, distributer cap, rotor, and coil/plug lines. I cleaned everything I came across while taking it apart and now it is back together. I confirmed that the timing is correct. When the key is turned to on, fuel flows out of the supply line so I know I am getting fuel, but it stops after a second or two so I'm not sure if the engine actually has to be running/turning over for a constant flow. I listened to each injector and heard clicking so I know they are working. All my vacuum lines and electrical connectors are attached. I replaced my fuel pump and filter about a year ago and the fuel pump fuse and relay are both good. My car WAS running before I took it apart, so I don't see how something could have just went bad, like a sensor or relay. After turning it over I pulled the plugs and only numbers 3 and 6 were wet (barely), the rest were dry. Any ideas?
Old Aug 13, 2011 | 09:54 PM
TNtech's Avatar
Did you orient the distributor the right way? You do know #1 tower is opposite where the rotor sparks the terminal?
Old Aug 15, 2011 | 10:43 AM
jdburns27's Avatar
Yes I know. The dist. rotor lines up correctly when at TDC
Old Aug 16, 2011 | 09:39 AM
TNtech's Avatar
OK, good. Now what I have seen MANY times on these older PCMs, is when the battery is disconnected for loooong periods of time, the PCM will go into theft mode when it gets woke up. It turns the fuel off. You need someone with a DRB to look at it for you. See if the fuel is off.
Old Aug 16, 2011 | 10:02 AM
jdburns27's Avatar
I know the fuel is on because I disconnected the supply hose and watched fuel pour out when cranking it.
LisaG
Jun 20, 2020 05:44 PM
GandJautomotive
Dec 30, 2013 03:30 PM
jdburns27
K-Cars
Apr 23, 2013 11:50 AM
roykaren
Jul 15, 2010 08:18 PM
