1995 Neon Heater A/C switch
Old Oct 25, 2007 | 05:27 PM
Rumblrr's Avatar
Default 1995 Neon Heater A/C switch
Hi i think i saw in a post a while back how you can disable the A/C from running when you select the heat mode on the fan control switch . I want to be able to run my heater in the vent or defrost mode when i select the warm or hotair mode on my heater switch any help would be appreciated . Thanks
Old Oct 25, 2007 | 07:01 PM
truck tech's Avatar
Default RE: 1995 Neon Heater A/C switch
Hello, the reason your a/c runs on heat mode is to dry the air so your windows will not fog up,plus it keeps things lubed up. I guess you are looking for more fuel mileage? It is not a good idea, if the a/c comp. does not cycle thru the winter months and keep things lubed up then you will be facing a high dollar repair come summer.I do not know how to shut it down but mabe Chryler Tech. or Moe may know. Good Luck!!!!
darkcild101
13
Jul 30, 2015 08:08 AM
traceyhanson
Nov 3, 2012 02:08 AM
mh90
Other
Feb 20, 2011 12:55 AM
porscheminitech
Nov 9, 2009 09:43 AM
abratt70
Jan 14, 2008 01:34 PM
