1999 chrysler 300m transmission issues
Old Feb 16, 2014 | 04:26 PM
tom66's Avatar
Default 1999 chrysler 300m transmission issues
I have 99 chrysler 300m. The car has 193k, i had issue with trans,it not go past 45mile an hour. I just changing solenoid pack,filter and trans fluild. Put all back together in place.Tart the car let they warm up then shift to reveres that five,when i put in drive the car just cut off. I no idea why they do that.
Could you help me with that problem. Thank you very much.
Old Feb 16, 2014 | 05:20 PM
tom66's Avatar
It has 3.5 v6.It was go to slim mode can't not past 45 miles.
Old Feb 16, 2014 | 06:44 PM
tom66's Avatar
[QUOTE=tom66;77145]I have 99 chrysler 300m. The car has 193k, I had a(n) issue with the trans, it does not go past 45mile an hour. I just changed the solenoid pack, filter and trans fluid. I put it all back together in place. Then I started the car, then I let them warm up, then shift to reverse, when I put in the drive, the car just cut off. I have no idea why that does that.
Could you help me with that problem? Thank you very much.
Old Feb 16, 2014 | 07:32 PM
Chrysler253's Avatar
Plug in a code reader, see what it reads.
Old Feb 16, 2014 | 08:02 PM
tom66's Avatar
I just put the key on and off for 3 times, and saw the code is p1684. I don't know what is for
Old Feb 16, 2014 | 08:22 PM
What is error code p 1684?
P 1684 is "Battery disconnected within last 50 starts"
What is error code p 168...
Old Feb 16, 2014 | 08:26 PM
Did you get a p0340 also?
Old Feb 16, 2014 | 08:27 PM
P0340
Camshaft position sensor circuit
Most likely cause : Camshaft position sensor failed.
P1684
means the battery was disconnected(or had been drained to a low voltage)
Old Feb 16, 2014 | 10:58 PM
tom66's Avatar
Because, no check engine light on,so i do not see another code .
Old Feb 17, 2014 | 06:00 AM
FIREM's Avatar
FWIW 99-01 speed sensors prone to failure, 02 and up solenoid pack suspect. Have the codes read with a code reader. Trans codes other than p0700 do not show up with the "key dance"
