2001 Voyager raditor Temp sensor location
Old Oct 10, 2010 | 11:07 AM
trvman's Avatar
Default 2001 Voyager raditor Temp sensor location
Anyone know where on line I can find a diagram showing where the temp sensor for the radiator is located on a 2001 Voyager?
Mine has gone bad I think as my guage doesn't always read. Not overheating or anything. I am also going to change the thermostat at same time.
No clue as to where the sensor is located.
Old Oct 10, 2010 | 01:24 PM
Need to know the engine size
Old Oct 10, 2010 | 01:47 PM
trvman's Avatar
Default engine size
It is a 3.3 V 6 engine.
Old Oct 10, 2010 | 01:48 PM
trvman's Avatar
Old Oct 10, 2010 | 08:10 PM
REMOVAL
WARNING: HOT, PRESSURIZED COOLANT CAN CAUSE INJURY BY SCALDING. COOLING SYSTEM MUST BE PARTIALLY DRAINED BEFORE REMOVING THE COOLANT TEMPERATURE SENSOR.
Drain cooling system below engine coolant temperature sensor level. (Refer to 7 - COOLING - STANDARD PROCEDURE)
Remove power steering reservoir and relocate (Power Steering Fluid Reservoir). Do not disconnect hoses.
Remove ignition coil and bracket (Fuel Rail, Ignition Coil and Bracket).
Disconnect coolant sensor electrical connector (Engine Coolant Temperature Sensor).
Remove coolant sensor (Engine Coolant Temperature Sensor).
Old Oct 12, 2010 | 10:10 AM
trvman's Avatar
Know where there is a picture that shows where all this is located?
I removed the two screws for the power stearing, but that is attached to another "box" that the plugs run into. I don't want to remove anything I should not be removing.
So I need a picture from a manual and if I have too, I guess I can try to find a manual on line.
Old Oct 12, 2010 | 10:32 AM
here ya go
Old Oct 12, 2010 | 01:29 PM
trvman's Avatar
It tells me I can't access the site to see the info.
If you can e-mail it too me, I would appreciate it.
Trvman1972@yahoo.com
Old Oct 21, 2010 | 10:12 AM
trvman's Avatar
I am still looking for anyone who can tell me where on line I can find a diagram showing where this temp sensor is located.
Old Oct 21, 2010 | 11:14 AM
TomC
Nov 30, 2014 01:56 PM
99ZQV8
Feb 21, 2012 10:45 PM
boatfund
Nov 26, 2011 06:44 PM
Kazzybrown
Sep 22, 2010 01:06 PM
faichu
Feb 20, 2007 07:26 AM
