94 Chrysler Concord 3.5V6 Overheating
Old Apr 25, 2011 | 06:28 PM
ausumwho's Avatar
Talking 94 Chrysler Concord 3.5V6 Overheating
Hi folks! I'm a mechanic in San Diego CA facing a daunting problem. I have a 1994 Chrysler Concorde 4 door sedan. It has a 3.5Ltr V6,auto, CA smog equipment. It runs great;no missing, no codes. Within ten minutes of starting
the engine will vaporize the coolent in the system. I replaced the water pump as it was evident it had been leaking. I replaced the radiator due to a pin leak near the seam on the tank. It holds perfect pressure when running,does not show any failure on a block test. After over heating,removing the thermostat housing shows absolutely no coolent present in the block. Please help me, I'm
at a total end of ideas.
Old Apr 25, 2011 | 06:42 PM
Djinn-n-Tonic's Avatar
Is there a t-Stat in the housing???? i'M ASSUMING IT JUST STEAMS OUT OF THE OVERFLOW TUBE?
Old Apr 26, 2011 | 12:49 PM
Possible reasons for overheating:
T-stat in backwards
Collapsed radiator hose
Blown head gasket
Plugged internal coolant passage
T-stat simply not working
Blown freeze plug
Probably some more that don't come to mind.
fmarshall04
Dec 13, 2012 09:32 PM
leeb
Aug 30, 2009 12:43 AM
wrangler04
Nov 15, 2008 08:08 PM
96RedLXI
Oct 20, 2007 01:49 PM
keesje
Mar 25, 2007 04:38 PM
