94 Concorde low/high beam issue
Old May 10, 2009 | 09:10 PM
Jack777's Avatar
Default 94 Concorde low/high beam issue
Just acquired a 94 concorde that doesn't seem to have low beams. There is no difference between the DRL and when I turn on the headlights. When I put the e-brake on and the running lights go off I turn on the headlights and get nothing. The previous owner says thats how they are just really dim I find that hard to believe. Another thing is when I pull back on the high beams they work and then as soon as i let go they go off. Is there no high beams that stay on on this vehicle ??
Kevin
Old May 11, 2009 | 10:46 PM
Try pushing the lever away from you rather than pulling it toward you. The pull is for a flash, pushing away clicks them on.
Old May 12, 2009 | 07:15 PM
Jack777's Avatar
I found the problem it was the light switch on the dash contacts were worn replaced the switch and everything is fine. On the 94 you pull back for highbeams they now stay on and low beams work too
Old May 13, 2009 | 03:04 PM
Good work.
nov_284
Nov 6, 2012 12:20 PM
captdantan
Feb 6, 2012 10:56 AM
lmekic06
Nov 13, 2011 03:52 PM
leortiz
Other
Sep 5, 2011 02:37 AM
ajs42548
Jan 19, 2011 01:45 PM
