94 concorde stalls while friving
Old May 26, 2010 | 10:37 PM
cops_263's Avatar
Unhappy 94 concorde stalls while friving
ok, here it goes, my 94 concorde stalls randomly when driving down the road especially on the highway and never throws a code. The engine just quits and the tach goes to zero. I have too wait a few seconds put the car in park and it will start again and sometimes run ok and sometimes stall again. The last time it stalled I went over a rough set of railroad tracks, I put the car in park turned off the headlights and the dash lights stayed on and it made this wierd buzzing sound. I replaced the plug wires just before all this started to happen, I have already replaced the ignition coil, plugs, wires, crank pos. sensor, fuel pump and fuel filter. It now seems electrical maybe, any help would be appreciated . I have seen alot of similar issues about this type of stalling and not many replies, someone has got to know somthing! thanks.
Old May 27, 2010 | 11:51 AM
You might have a loose or corroded ground strap somewhere that is intermittently breaking contact. Check, clean and tighten all that you can find. Can't hurt; won't cost anything; might help.
Old May 27, 2010 | 12:41 PM
cops_263's Avatar
ok.. thanks keep u advised ...any ideas where to start?
Old May 27, 2010 | 01:39 PM
cops_263's Avatar
ground straps are tight cleaned , still stalls on highway, found two on passenger s side connected to block, one went to frame the other car body
Old May 27, 2010 | 01:40 PM
cops_263's Avatar
checked old stored codes and still showing battery disconnect from last start and also power loss, ECM reset, codes 11 and 12 .
Old May 27, 2010 | 01:41 PM
cops_263's Avatar
however did not disconect batt. in a while also showed codes 54 and 32 but engine light on at all
Old May 27, 2010 | 01:42 PM
cops_263's Avatar
not on at all i mean
Old May 27, 2010 | 10:35 PM
Might want to remove and clean the battery cable connections too. Battery connections can be strange. A corroded connection can sometimes pass a current if it's large enough, but not pass a small current, and vice-versa. That random 12 code may be a clue.
Old May 28, 2010 | 09:28 AM
cops_263's Avatar
already been done
Old Jun 24, 2010 | 06:36 AM
huasi87's Avatar
Dose your car Erase All the code when It Stalls. If So didi you check Allternator For AMPs While driving and have you make sure that the AirMass sensor is working Fine and the throttle is responsing correctly and dosent get stuck.
