96 ecm computer
Old Jan 16, 2010 | 07:15 PM
jackson521's Avatar
Default 96 ecm computer
Are the ecm and the body computer grounded by screws...also wat can cause the electric choke not to work on car??
Old Jan 16, 2010 | 10:40 PM
no such thing as an electronic choke on a fuel injected car.
Old Jan 17, 2010 | 12:16 AM
jackson521's Avatar
aw ok well i need a lil help i have a 96 chrysler cirrus car starts up idles high and cuts off and does this will not constanly run i have recently put a new ecm in the car car wasnt getting any spark or gas and now that i put the ecm in the car this is all its doing now car was running jus fine till ecm went out im lost.
Old Jan 17, 2010 | 06:31 AM
where did u get eh pcm from and is it the same part number as the on u took out?
Old Jan 17, 2010 | 08:41 AM
jackson521's Avatar
i got the computer from a auto salvage yard part number was bot the same same numbers as the one i took off i had abn interchangable part number computer came off same year car with same size motor 96 cirrus 2.5
Old Jan 17, 2010 | 10:45 AM
what were the part numbers for both
Old Jan 17, 2010 | 05:03 PM
jackson521's Avatar
4606275 and the one i got from the yard is 4606213...somebody told me that i need to get the computer flashed/programmed because car is starting and running for bout 7-8 secs and cutting off...car will let me give it gas wen first start but cuts off in the same time frame.
Old Jan 17, 2010 | 06:00 PM
it wont work no u cant just flash a pcm once the software is in there its there for good the pcm u have wont work it for a different setup then u have.
If u think u need a pcm visit
autocomputerexchange.com and get the right one for your car.
Old Jan 17, 2010 | 06:19 PM
jackson521's Avatar
o i c cause the computer i got was supposed to be interchangeable part number from same year and make...also i lost original set of keys does the 96 cirrus have chip in key or remote
Old Jan 17, 2010 | 06:22 PM
jackson521's Avatar
i took a look on that website in they said no parts matching that
