99 LHS Fan won't blow
Old Feb 2, 2009 | 03:13 PM
fryegirl's Avatar
Default 99 LHS Fan won't blow
I Have a 99 LHS and the fan won't blow... I can feel there is heat, How do I trouble shoot it and fix it?? It is equipped with the climate control, will that make a difference?
Old Feb 2, 2009 | 06:06 PM
The automatic temperature control system has a blower control module to control the blower. It could be that or it could be a bad blower motor. You could apply 12 volts to the motor to see if it will turn. If so, then the module is likely the problem.
Old Feb 19, 2009 | 04:46 PM
irdaneel's Avatar
Have you checked your fuses? There are usually at least 2 places to look. One is under the dash somewhere, the other is under the hood.
If you have a manual, read it to find where your fuse boxes are located.
The one inside is usually called the fuse panel
The one underhood is usually called the PDC, or Power Distribution Center.
The manual will tell you what you have and where it is located. Then look on the covers of the panels to see which fuse does what. Look for the heater circuit. Be sure to replace any burned out fuses with identical ones. Most Kragen stores will actually help you, maybe.
slamkin
Mar 28, 2012 05:24 PM
drcbart
Aug 2, 2009 07:05 AM
aspangenberg
Feb 7, 2009 02:38 PM
itchybird
Oct 14, 2008 06:32 PM
nicktheiscar
Aug 27, 2006 08:45 PM
