cirrus
I have a 1999 Cirrus with 114,000 miles on it. Sometimes after driving for about 1/2 hour the motor will just shut down with no engine codes coming up. After it sits for about 15min to 1/2 hour it will start right back up with no problem. If you try to start it prior to that it will just crank over with no start. I have replaced the Plugs, Cap, Rotor. and the Wires. I have droped the fuel tank changed the fuel filter and cleaned the pickup screen for the fuel pump. When the motor stalled I pulled the fuel line and cranked the engine plenty of fuel. I would like to try and fix it myself instead before I try to go to a dealer but I am running out of ideas. If anyone has an idea or solution it would be very helpful. Thanks
