disabling car alarm
Old Mar 8, 2009 | 07:14 PM
blu04srt4's Avatar
Default disabling car alarm
My dad has a 1999 300. he bought the car at an auction and it didnt come with a key. is there anyway to disable to alarm and run the car without the chip that is inside of the key?
Old Mar 8, 2009 | 08:59 PM
yep its gonna cost u more then a new key though
need a new PCM and remove the skim module.
and replace the BCM as well.
Old Mar 15, 2009 | 04:29 PM
blu04srt4's Avatar
Is there any way to bypass the pcm to start the car? My dad bought a new key for his car, but it wont accept it when gets programmed. What can he do about this, the tech at the dealership doesnt know what to do? Thanks for the help guys.
Old Mar 15, 2009 | 07:22 PM
The dealer will have to have the four digit PIN for the vehicle. They will also need to cut a blank transponder key to fit the ignition lock. After inserting the new key in the ignition and turning it to the "RUN" position, the tech will then use the DRB III scan tool and select "Theft Alarm", "SKIM", "Miscellaneous" and then "Program New Key". At this point he will need to enter the four digit PIN code for the vehicle. The DRB should then be able to program the new key. Have them make 2 keys if you are going to go through this. With two keys, you can program additional keys yourself (up to a total of 8 for the vehicle.)
If the car will not start at this point there may be a failure of the SKIM to communicate with the PCM or BCM which will require figuring out why that is not happening.
You can't "bypass" the pcm and start the car. The pcm controls the engine and is an integral part of the operation of the engine. Sometimes the system can get confused if there are two keys right next to each other. Make sure only one key is present when you attempt to start the car.
Old Mar 15, 2009 | 09:36 PM
get a better tech at the dealer would be my first start.
sebringing
Jul 24, 2011 05:13 PM
300Cchamp504
Dec 14, 2008 07:11 PM
dmlover76
Cirrus & Breeze
Apr 20, 2008 12:43 AM
muso58
Jun 26, 2006 03:18 PM
jrandis04
Nov 29, 2005 10:22 PM
