Drive axle nut size ??
So I need to replace the wheel bearing on the front pass side of my 96 Sebring Convt. and realizr that I don't have a socket large enough to fit....is it a 33MM does anyone know ??
Thanks for any replies!! |
Socket is 1 1/4.
It's probably a metric size equivalent to 1 1/4, which would be closer to 32 mm.
To replace the hub bearing you'll need to disconnect the ball joints and pull the steering knuckle. |
2011 Chrysler 200 wheel bearing / hub assembly changeout
Originally Posted by master tech
(Post 35364)
Socket is 1 1/4.
Axle Nut
Both 32mm and 1¼ in. works. On a 2011 200 you don't need to pull the knuckle off to change the bearing hub. It can be done using penetrating oil and a heavy hammer. Take the axle nut off first, then push the shaft back for enough room to get the bolts out.
