Front End Play/99 300M
Old Oct 5, 2009 | 05:46 AM
funjon1's Avatar
Default Front End Play/99 300M
Aclunking noise has developed in the front end of my 99 300M, mainly when I turn the steering wheel. I raised the car, grabbed the left front wheel at the 3 and 9 position, and wiggled it. There is some play in it. Does this indicate a bad inner tie rod? If not, what are the other possibilities? Thanks in advance for your help.
Old Oct 6, 2009 | 09:51 PM
funjon1's Avatar
Default Front End Troubles/300M
Found that the clunking noise and steering wheel shudder was due to a worn out inner rack and pinion bushing. I replaced the same bushings on an Intrepid a few years back. My question is this..... how do you bend up the lower lock tabs that go over the nut holding the tie rod to the rack? I can hammer the top ones down but can't do anything with the bottom tabs. Thanks in advance for any helpful answers given.
Old Oct 7, 2009 | 08:52 PM
Do you own a BIG pair of groove-joint pliers? Years ago I bought a 16 inch groove joint pliers from Sears. It's one of the most useful tools in the collection. Great for grabbing and bending.
steve392
Dec 21, 2008 07:45 PM
ghlkal
Mar 18, 2008 09:16 PM
PDQ Hemi
Dec 29, 2006 02:07 PM
gxs0lvi
Nov 7, 2006 08:10 PM
rfarkas
Aug 24, 2005 03:15 PM
