fuel pump
Old Nov 30, 2020 | 04:16 AM
1Tazz's Avatar
Thank you very much i thought i was going crazy. Every thing is working on the car, runs good when i add gas to throttle body. When I first turn the switch on there is no prime for the pump . She said it was running good when parked, it has the 3.0 motor.
Old Dec 4, 2020 | 04:25 AM
1Tazz's Avatar
I am getting power at the fuel pump relays ,and relays are good still no prime at pump when key is turned on. Just about at the end of the road on what i can do with this car. Seems crazy every thing works but no codes showing. this is the 2002 lei coupe with a 3.0 v6 motor runs when we spray gas in the throttle body.
Old Dec 10, 2020 | 12:42 PM
Marcelvg's Avatar
make a wire 12v from your key (where you start)to the fuel pomp
a sort of bypass
Old Dec 10, 2020 | 01:12 PM
1Tazz's Avatar
Man you saved the day i jumped it with a switched 12 volt source and it is running like a top . i was thinking it had to prime then cycle on and off . I and going to drive it like this.
Brent Samuels
13
Mar 3, 2020 03:15 PM
maintenance
Apr 30, 2015 05:15 PM
seqx34
Dec 14, 2014 07:24 PM
moose7171
Jun 4, 2008 04:59 PM
JasonB
Jul 6, 2007 12:00 AM
