Heating, Ventilation and Air-con lights flashing.
Old Jan 7, 2007 | 03:09 PM
jstwhi1's Avatar
Default Heating, Ventilation and Air-con lights flashing.
Hi there. I'm from England and need a bit of info please. Can anyone tell me how to turn off the flashing lights on the fore mentioned buttons? They stay flashing after the ignition is turned on, for about 15 minutes. Thanks.
Justin.
Old Jan 7, 2007 | 03:11 PM
jstwhi1's Avatar
Default RE: Heating, Ventilation and Air-con lights flashing.
Sorry, stupid me. Forgot to mention I have a Grand Voyager, year of manufacture-97 3300 LE
Old Jan 7, 2007 | 08:00 PM
here ya go u need to recal the ac head sence the battery was replaced or disconnected.
CALIBRATION/DIAGNOSTICS TEST ENTRY TO INITIATE TESTS: [ul][*]Set Blower motor ON HIGH[*]Set Mode position to Panel[*]Open all A/C outlets[*]Set Temperature to Cold (Both slide pots if equipped)[*]Depress WASH and REAR WIPER button simultaneously for 5 Seconds (Until all LED's light) [/ul] RESULTS: [ul][*]All LED's will turn on for 5 Seconds[*]Calibration Test is running when REAR WIPER and INTERMITTENT are alternately flashing. Cooldown test is running if A/C and RECIRC are alternately flashing.[*]Acceptable results is REAR WIPER LED is the only LED flashing. Push Rear Wiper to exit.[*]After all tests have passed, Calibration Diagnostics and Cooldown can be run separately. [/ul] COOLDOWN TEST ENTRY TO INITIATE TESTS: [ul][*]Set Blower motor ON HIGH[*]Set Mode position to Panel[*]Open all A/C outlets[*]Set Temperature to Cold (Both slide pots if equipped)[*]Depress WASH and A/C simultaneously for 5 Seconds [/ul]
Jason1969
Jul 8, 2013 09:35 PM
chanceboy
Jul 2, 2012 04:44 PM
E74776
Nov 24, 2007 02:13 PM
vivsor
Jun 4, 2007 04:59 PM
cardinal5
Dec 13, 2006 11:54 PM
