Low Beams stopped working (non HID)
Old Jun 20, 2008 | 09:01 AM
johnseattle's Avatar
Default Low Beams stopped working (non HID)
Can someone please give me some advice. The low-beams on my 2005 Pacifica have both stopped working. All other lights work normally. I have checked the bulbs and the BCM fuse. I put my voltmeter on the headlamp plug and was only reading 4v - that was with the headlamps switched on or off. I am figuring that it is either the ballast or the switch itself. Where is the ballast module located? Or does anyone have any better 'brighter' ideas (no pun intended).
Thanks in advance.
Old Jun 20, 2008 | 07:47 PM
RobS's Avatar
Default RE: Low Beams stopped working (non HID)
4V indicates high resistance someplace, I would first check the ground, because a loose ground will cause excessive resistance. Also your switch, internally could be faulty, it is not uncommon
Big_Rob
Nov 25, 2012 12:17 PM
penniman16
Dec 10, 2011 03:52 PM
scott04
Dec 16, 2009 08:41 PM
sonic gihad
Jan 27, 2009 08:29 AM
johnseattle
Jun 20, 2008 02:11 PM
