moe7404
Old Nov 11, 2007 | 07:39 PM
moe7404's Avatar
Default moe7404
Duel point disturbers
By morris shouse
This is an instruction set as to how to install a pair of points on mopar duel point disturbers, old style hemis, small and big blocks. First get two sets of new points. Then you need to adjust the movable point so it seats flat to the solid point. This is very important to get the points to seat flat. But be careful and bend the movable arm only between the rubbing block and the point. now clamp the shaft tang in a vice with the shaft up and down. Now remove the old points. Put the new ones in. take some cardboard and block one set open then get a feeler gauge .015 thick and 3/16 to ¼ wide and one to one and half long. It must be .015 thick, I know the spec is .017, but trust me .015 will get the total dwell angle to 42 degrees. Now put the feeler gauge in the set that doesn’t have the cardboard in. now the the idea is that one or two lobes are higher than the rest. So what we do is rotate the dist.Housing very very slowely. And adjust the set so that the gauge only falls on the highest lobes. You must put no side pressure on the housing. Its very important that the gauge falls only on the highest lobes. This may take a while, but be patient. Then move the cardboard to the other set of points, and adjust the other set. When you are done you should have 42 degrees total. Just don’t get in a hurry.
Old Nov 12, 2007 | 05:44 PM
moe's Avatar
moe
Default RE: moe7404
hey moe!!
Old Dec 28, 2007 | 12:24 AM
moe7404's Avatar
Default RE: moe7404
moe in wichita kansas
sorry to hear you live in N.J. ha ha. the other day i counted up how many mopars my dad and i have owned aprox. 35. old style hemis, maxi wedges, 413s, 440s. slant 6s. flathead 6s. right now all i have is a 2001 dak v6. in 1969 my dad and i put a 392 hemi in a 59 ply wagon, my dad kept racing GTOs but couldnt beat them, i had to tell him there isnt a way to beat them cause your 1000 lbs heaver. i had a chrysler 300L, totaly stock i got to go 16.0 in the 1/4 mile 85 mph. dad had a 1963 300J with a 500 inch 440 maxi wedge heads, manifold, cam, 3000 stall converter, 2.72 rear end. it cam out of second at 120 mph. it cost a lot to drive it, but sure was fun. dad would always say " mopar or no car
