Need help
I have a 2002 Chrysler Voyager with a 2.4L Yesterday I turned to the right and the engine stalled out and couldnt get it started so i had it towed home thinking it might be the fuel pump. This morning i disconnected the fuel line from the fuel rail turned the key and fuel is coming out of the fuel line with plenty of pressure so i connected the line back to the rail. I hooked up a noid light to the coil turned the key and there is no spark coming out of the coil so i replaced the crank sensor and cam sensor and still no spark coming out of the coil any suggestions? Should i replace the coil as well? What if i still get no spark what can it be?
get a test light disconnect the coil U will have a power and 3 grounds when cranking the car if U have that then yes could pack is more then likely bad If u don't have those then u have another issue.
I did that as well there is nothing coming out of those wires the test light did not come on at any of the three wires
to check for battery voltage the clip end goes on the plus battery to check for a ground circuit the clip part goes on the negative post
U have some one helping u out with this? turning over the engine while U have the pins probed? |
