Need help
Old Oct 24, 2012 | 07:18 PM
joetat's Avatar
Default Need help
I have a 2002 Chrysler Voyager with a 2.4L Yesterday I turned to the right and the engine stalled out and couldnt get it started so i had it towed home thinking it might be the fuel pump. This morning i disconnected the fuel line from the fuel rail turned the key and fuel is coming out of the fuel line with plenty of pressure so i connected the line back to the rail. I hooked up a noid light to the coil turned the key and there is no spark coming out of the coil so i replaced the crank sensor and cam sensor and still no spark coming out of the coil any suggestions? Should i replace the coil as well? What if i still get no spark what can it be?
Old Oct 24, 2012 | 09:27 PM
get a test light disconnect the coil U will have a power and 3 grounds when cranking the car if U have that then yes could pack is more then likely bad If u don't have those then u have another issue.
Old Oct 25, 2012 | 09:36 AM
joetat's Avatar
I did that as well there is nothing coming out of those wires the test light did not come on at any of the three wires
Old Oct 25, 2012 | 01:31 PM
to check for battery voltage the clip end goes on the plus battery to check for a ground circuit the clip part goes on the negative post
U have some one helping u out with this? turning over the engine while U have the pins probed?
JamesBraxton
Sep 18, 2011 09:01 PM
s.wilson1978@yahoo.com
Jul 12, 2011 02:19 PM
musicfreak2195
Sep 19, 2008 12:47 AM
ETD66SS
Jul 3, 2005 01:33 PM
nypdalamo77
May 26, 2005 12:41 AM
