No EGR valve
Old Feb 17, 2012 | 06:38 PM
Tracy c's Avatar
Default No EGR valve
I have an engine code of PO403 and was told the problem would be the egr valve, problem is my van an 02 town and country has no erg valve. what could make the code come on given no egr valve
Old Feb 17, 2012 | 08:09 PM
Which engine do you have?
Old Feb 17, 2012 | 11:13 PM
NUMBER: 18-026-01
GROUP: Vehicle
Performance
DATE: Nov. 2, 2001
This bulletin is supplied as technical information only and is not an authorization for repair. No part of this publication may be reproduced, stored in a retreival system,
or transmitted, in any form or by any means, electronic, mechanical, photocopying, or otherwise, without written permission of DaimlerChrysler Corporation.
SUBJECT:
EGR System Elimination
OVERVIEW:
This bulletin provides technical details about the elimination of EGR valves.
MODELS:
2002 (RS) Town & Country/Caravan/Voyager
NOTE: THIS BULLETIN APPLIES TO VEHICLE WITH A 3.3L OR 3.8L
ENGINE (SALES CODES EGA, EGH, EGM).
DISCUSSION:
A running change to eliminate the EGR system is being made during the 2002 model year.
The change will be made in steps. First, the EGR will be turned off in the calibration (PCM
software), followed by the removal of the EGR valve. This left a period of time during
which vehicles were built with a non-functioning EGR valve on the engine. The following
information will help to identify and service a functioning versus non-functioning EGR valve:
• Vehicles with functioning EGR valves.
Vehicles built before September 18, 2001 (MDH 0918XX) at the Windsor Assembly
Plant (”R” in the 11th position of the VIN) and September 14 (MDH 0914XX) at the St.
Louis Assembly Plant (“B” in the 11th position of the VIN) will have functioning EGR
valves. Normal diagnostic and service procedures apply.
• Vehicles built with non–functioning EGR valves.
Vehicles built after the dates mentioned above through approximately the end of
October, 2001 will have a non-functioning EGR valve on the engine and may or may not
have an EGR vacuum harness. Vehicles built after approximately the end of October,
2001 will not have an EGR valve on the engine. In either case, the vehicle VECI label
will identify the EGR valve “non-functional” and have a dotted line to the EGR valve.
For non-functional EGR equipped vehicles electronic diagnostics will not function,
however, the electrical connection must be maintained if the vehicle has an EGR
vacuum harness (the EGR solenoid must be energized to shut off vacuum flow to
the EGR valve). If the vehicle does not have an EGR vacuum harness the electrical
connector may or may not be disconnected and taped back to the harness.
If a non-functional EGR valve is diagnosed with a problem, the EGR valve must be
removed and cover plates installed, per the following procedure:
18-026-01 -2-
PARTS REQUIRED:
Qty. Part No. Description
1 04591227 Plate, EGR Cover, Head
1 05277723 Gasket, EGR Cover, Head
2 06503692 Screw Cover Plate, Head
1 04861623AA Plate, EGR Cover, Intake Manifold
1 03580172 Plug, EGR Vacuum Intake Manifold
REPAIR PROCEDURE:
NOTE: THIS PROCEDURE APPLIES TO VEHICLES BUILT AFTER SEPTEMBER
18, 2001 (MDH 0918XX) AT THE WINDSOR ASSEMBLY PLANT (“R” IN THE
11TH POSITION OF THE VIN) AND SEPTEMBER 14 (MDH 0914XX) AT THE ST.
LOUIS ASSEMBLY PLANT (“B” IN THE 11TH POSITION OF THE VIN) WITH
NON-FUNCTIONING EGR VALVES AND AN EGR VALVE PROBLEM .
1. Remove the two screws holding the EGR tube to the upper intake manifold, and save
for reuse (the silicone sealing ring will remain on the intake manifold).
2. Disconnect EGR vacuum connector from nipple on upper intake manifold (if present).
3. Remove the entire EGR valve assembly with adaptor base from the
cylinder head including EGR tube.
4. Install EGR cover plate, p/n 04861623AA, onto upper intake manifold using the two
screws saved in Step 1. Ensure that the words “THIS SIDE UP” are visible on the
cover plate after installation. Tighten screws to 4 Nm (35 in. lbs.).
5. Install EGR cover plate onto the cylinder head, using gasket, p/n 05277723,
and screws, p/n 06503692. Tighten to 28 Nm (250 in. lbs.).
6. Install cap, p/n 03580172, onto EGR vacuum nipple on upper intake manifold.
7. If the EGR electrical connector is not already taped back to the
wire harness tape it to the harness.
POLICY:
Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Operation No: Description Amount
25-01-45-97 EGR Valve, Remove and Cap 0.3 Hrs.
FAILURE CODE:
AM Authorized Modification
Old Jul 18, 2012 | 03:09 PM
voyager52's Avatar
hi i recently swapped engines over bought a 2001 engine and fitted it to a 2002 , the 2001 engine had a egr valve and mine didnt the garage changed the manafold over so my current car was a straight fit ,but since the change at 3250rpm it dies then re picks up after about 2 seconds is this due to the erg vavle
Old Jun 10, 2015 | 06:28 PM
SBruceMB's Avatar
Default '02 t&c
Having the same problem as OP. My '02 T&C has no EGR valve and is throwing a p0400 code. Has hesitation / misfires while driving. There's no place on the cylinder head where one ever was, but there is a port with a cover installed on the intake manifold. What should I be checking?
Old Oct 20, 2015 | 07:05 AM
cOoLjOhn652's Avatar
Mostly after over hauling and most probably after fitting it again. Sometimes it just do misfire.
Old Feb 18, 2018 | 01:24 AM
Jobu's Avatar
NUMBER: 18-026-01
GROUP: Vehicle
Performance
DATE: Nov. 2, 2001
SUBJECT:
OVERVIEW:
MODELS:
DISCUSSION:
18-026-01 -2-
PARTS REQUIRED:
REPAIR PROCEDURE:
POLICY:
TIME ALLOWANCE:
FAILURE CODE:
....please answer the question.....
what to do about the code?????
thank you...
Old Feb 18, 2018 | 06:05 PM
------- please read the tsb--------
Old Feb 18, 2018 | 10:23 PM
Jobu's Avatar
I did, it did not mention anything about the error code. It's as if Chrysler removed the EGR system, but did not tell the computer to overlook the fact that it is not there. Now my vehicle won't pass inspection because my engine light is on, because there is a fault in the EGR system that was removed by the manufacturer. Is there a way to bypass this? Maybe a special plug for the harness plug that would otherwise be plugged into the EGR valve? Cheers!
stevep
Oct 8, 2016 08:25 AM
stevep
9
Mar 30, 2011 09:57 PM
96RedLXI
Oct 20, 2007 01:49 PM
96RedLXI
Sep 17, 2007 09:31 AM
kevinc
Apr 29, 2007 11:51 PM
