No Start 99 300M--- 3.5
Old Mar 23, 2009 | 08:33 PM
funjon1's Avatar
Default No Start 99 300M--- 3.5
Had the battery disconnected for a couple days while I was replacing valve cover gaskets. I put it all back together today and the car won't start. It's getting gas to the injectors and there is current reaching the coil packs. Could having the battery disconnected for 48 hours have any effect on the factory security system? Like I said, it cranks real strong but won't fire up! Thanks in advance for any help anyone may have for me.
Old Mar 24, 2009 | 04:32 PM
Any codes? The usual mode for the security system is to shut the engine off after 2 seconds.
Are you sure you didn't mix up any connections in putting it back together? Some of those sensor connectors can be mixed up easily.
Old Mar 24, 2009 | 05:09 PM
funjon1's Avatar
Thanks for the feedback dcotter. Everything appears to be properly plugged in and can't see any broken wires. Probably just overlooking something. I to am a suburban Detroiter. East side!!
Old Mar 24, 2009 | 07:38 PM
Probably gonna have to slap a code reader on there to see if anything comes up. In the meantime, see if you have an actual spark. Might want to get an ignition tester.
Let's hear it for the East side. I'm in Grosse Pointe Park. Where are you?
Old Mar 24, 2009 | 08:19 PM
funjon1's Avatar
I'm in Harper Woods. Hate to have to get the car towed somewhere to have a code reader put on it. I'm assuming that I need a dealer-type scanner put on it, not the basic one that Autozone has.
Old Mar 25, 2009 | 03:49 PM
Current to the coil pack doesn't mean that you have a spark. To create a spark, the current is interrupted causing the magnetic field to collapse on the primary side of the coil and that induces the current in the secondary side of the coil. It's that induced current that causes the spark.
So check for a spark. If no spark, then you need to run that down.
peterjv
Apr 21, 2011 12:45 PM
nates90
Mar 15, 2011 09:36 AM
kikinz24
Oct 29, 2009 06:28 PM
funjon1
Feb 12, 2009 02:11 PM
funjon1
Jun 19, 2008 03:57 PM
