no start< Stratus sebring
Old Jun 4, 2022 | 02:40 PM
patrick1955's Avatar
Default no start< Stratus sebring
stratus conv 1996 ,2.5l
car is crank ,but it will not run, no speedo,gas,rev.,,...meters are working on the dach , radio yes, chime bel o.k. gasolina o.k.
where can i start looking,
i think electr, connectors, fuses,
Old Jun 4, 2022 | 08:58 PM
codes in the computer? put a scanner on it see if you can see cam and crank signal
Old Jun 11, 2022 | 07:42 AM
ggoose's Avatar
Need to determine if it is no spark or no fuel.
Spray some starting fluid or carb cleaner into the throttle body and crank the engine. If there is spark, the engine will fire but die out. If the engine fires and dies you may be looking at a fuel pump. Fuel pressure should be at least 45psi. If the engine does not fire, common culprits are the crank position sensor or the cam position sensor (part of the distributor). You would need a good scanner to read the crank and cam position sensor signals.
Old Jun 11, 2022 | 07:50 AM
yes, i have spray in carb, there is spark it run,
but no fuel comming.and No cluster movement,,only temp needle is little moving.
Old Jul 15, 2022 | 12:09 PM
boatmoter's Avatar
plugged fuel filter, defective fuel pump, out of fuel, anti theft killing the fuel pump
Old Jul 31, 2022 | 05:20 AM
today, i check fuel pomp, if its working.
patrick1955
Jun 4, 2022 02:39 PM
blasar
Apr 11, 2021 03:43 PM
Txitxo1968
Jul 23, 2019 02:48 PM
Melssj5
Apr 23, 2012 05:48 PM
Jun 23, 2006 11:12 PM
