no washer fluid coming out (2005 T+C Van)....
Old Feb 17, 2007 | 03:39 PM
jasons4's Avatar
Default no washer fluid coming out (2005 T+C Van)....
I've checked the fuse for the washer fluid motor and it's fine.
I do not hear the motor trying to pump when I activate the washer fluid squirters.
Is the pump located at the bottom of the fluid reservoir like most other ones I've seen?
Do you get at it from the passenger side fender?
Any way to test the pump?
Thanks in advance.
Old Feb 18, 2007 | 01:41 AM
Default RE: no washer fluid coming out (2005 T+C Van)....
check for power and ground at the motor use a drb to acuate the pump see if the input to the IPM is there
Old Dec 24, 2007 | 12:33 PM
finlandmauri's Avatar
Hi,
I have the same issue with my just-bought 2001 T&C. Chrysler Tech, I want to do what you had explained there. Could you just tell what do these mean: DRB and IPM?
Thanks!
Old Dec 24, 2007 | 04:59 PM
the DRB is a chryer scanner only a dealer will have this the IPM is the fuse box under the hood.
Old Dec 24, 2007 | 10:40 PM
thank you for clarifying! merry xmas to all!
2009DodgeGrandCaravanSXT
Jul 1, 2013 09:57 PM
dmarshall85
Dec 18, 2010 07:30 AM
sonician
Oct 28, 2010 04:35 AM
epd
Mar 2, 2008 09:42 PM
quattj
Apr 2, 2007 03:29 AM
