OK TECH Q. Retrofit of a 61' 361 to run with PCV
Old Sep 15, 2015 | 09:52 AM
FEandGoingBroke's Avatar
Default OK TECH Q. Retrofit of a 61' 361 to run with PCV
OK Just as the title says, Got a 61' 361 2V carb.
It's a re-man carb and I cant for the life of me to get it to run and idle properly without adding a big vacuum leak to the base of the carb, which technically means the carb is setup for something other than a road draft system.
So has anyone done it before and have any part information on which PCV valve to use, or from what application you got one, or am I the only fool that likes his engines to last well over 200K with oil changes only every 6 to 7000 miles?
Thanks,
FE
Chrysler Forum Editor
Dec 20, 2013 03:58 PM
theblitz6794
May 7, 2012 03:41 PM
rmbb
Jun 15, 2011 09:06 AM
TwinsFan
Feb 16, 2009 01:39 PM
Hi_Def
Mar 3, 2008 10:26 AM
