Pacifica only tries 1/2 a start, sometimes
Any and all help would be very appreciated. I've read as many forums as I can find with no luck. Even the dealer is stumped.
I've got a 2004 Pacifica. Sometimes when you try to crank it, it will give one good solid 1/2 "crank" sound, but nothing else. It sounds like it gets 1/2 way through it's crank and gets jammed/suddenly stops trying. There's no additional sound, just a sudden silence that seems to come about 1/2 a second before you'd expect it to pause between cranks (and then nothing until you release and try again). Sometimes it takes 3-7 turns to get past the single crank and get it to actually start the car. Sometimes, it cranks right up on the first hit. They've done a drain test on the electrical system, it's well within tolerances (just the little bit needed for things like the remote doors, etc). - I replaced the battery. No change. - They replaced the starter (twice). It got more frequent. - They replaced some computer module known to flake out (Sorry, don't recall the name) No change. - They replaced the ignition switch. No change. When it chooses to start, it acts as though nothing was ever wrong. There's no stalling when running. It never acts like a loose wire (where sometimes you turn the key and get zero sound, other times it's fine). Every time it doesn't start it still gives one good solid 1/2 crank sound, but dead silence follows. The dealer (same one) installed a remote start kit for us 9 months ago, but we've experience no problems starting until this month. I don't think it's related, but mention it just in case. If anyone has ANY ideas, please please help. I'm afraid I may have a very expensive metal brick on my hands. Zig |
RE: Pacifica only tries 1/2 a start, sometimes
torgue converter
| All times are GMT -5. The time now is 05:23 AM. |
