Please help my 73 Satellite Wagon run right
Hello, so my 73 Satellite wagon has a 318 with a 2BBL Carter carb, and when I got it, it drove home 1 1/2 hours just fine, but after that it would stall out when I gave it gas. I changed the air cleaner, fuel filter, cap, rotor, wires, charcoal canister filter, plugs, and rebuilt the carb. Soon it grew out of that habit and took on a new one; it would only run for a couple of minutes and then die out, not wanting to start again for a while. Once it died, I tried starting fluid and it would fire up again for a few seconds, most likely indicating a fuel problem...so I replaced the fuel pump, which helped a little. So now what it does is idle nicely for 5-6 minutes, the idle rises quite a bit, and then it will eventually die out. Even now, it wont start back up unless I use starting fluid or wait a long time. I am suspecting the choke at this point, since it seems to happen when the car heats up, and the idle changes when the choke moves. Any suggestions on what I should check or how to fix this?
I would suggest a fuel-system-cleanout...
remove/empty/clean out fuel tank/pickup-and-strainer... ensure new fuel filter (if you havent already)... Use some gas dryer on 1st restart... just in case some water was/is in the lines... Hope that helps! :D |
