Proxy Alignment??
Old Mar 13, 2021 | 12:54 PM
beastinem's Avatar
Default Proxy Alignment??
Ok, so my wife has a 2015 Chrysler 200. Her odometer started flashing all of the sudden, then we realized the radio and A/C vents don’t work and the car battery was dead. We jumped the car. Radio and A/C vents still didnt work and the battery was dead again in 2 days.Here is a list of steps we went through.
1. Took it to Firestone. They said the battery and alternator looked good. Said the diagnostic showed a bunch of codes they didn’t understand and recommended we take it to a Chrysler dealership.
2. Took it to a dealership. They ran a diag and said its a bad battery.
3. Took it to O’Reilys and the guy said the battery and alternator were fine but swapped out the battery anyway.
4. 2 days later, car/battery was dead again.
5. Took it back to the dealership and they said it needs a proxy alignment but they cant do it without a working radio.
6. Found a used radio on ebay for $70 since Chrysler quoted me $800.
7. Swapped the radio out myself. So now the radio work and A/C vents work but the odometer is still flashing.
My question is, do I really NEED this “proxy alignment”? Will the battery and/or radio be damaged again if I do not get it done? It costs $165 that I really do not have!
Old Mar 14, 2021 | 02:35 PM
ggoose's Avatar
Proxy alignment essentially resets all of the computer modules so they can reload/learn the most recent configuration.
One method that is sometimes effective is to disconnect both of the battery cables from the battery and touch the battery cables together for 10-15 seconds. This resets the computers and when powered back on will cause a reload/learn of the last stored configuration so all of the computer configurations match.
Old Apr 7, 2022 | 05:08 PM
joortiz22's Avatar
@ggoose I have Same problem. is this what we need?
Old Jun 9, 2024 | 11:38 AM
Jhay's Avatar
your dealer is charging you $165 for the proxy alignment ? If so it’s not bad. If the battery trick didn’t work I say safe up and do the proxy alignment.
Old Jun 9, 2024 | 11:39 AM
Jhay's Avatar
did this work for you ?
Connor Mink
Sep 21, 2017 10:27 AM
albo23
Oct 17, 2011 10:44 PM
mpcklb
Jun 13, 2011 10:04 AM
pdh
Apr 21, 2009 04:16 PM
sebringpower69
Feb 18, 2007 01:43 AM
