radio/locks
Old Jul 4, 2008 | 02:14 PM
kenzspen's Avatar
Default radio/locks
i need someones help i have a 2001 seb conv 48k, it blows the #5 fuse in the inside junction block and the radio and locks do not work, under further diag found had no brake lights found fuse in underhood junction block blown if i install fuse in brake light spot lights work until i install interior #5 fuse so to sum up these 2 fuses cannot be installed at the same time without on or the other blowing. i have unplugged following components to check if they were the problem, radio,brake switch, power lock switch on d/s door any help would be greatly appreciated
Old Mar 8, 2014 | 02:23 PM
mekeeton's Avatar
I had a similar problem with my 2004. I had no radio, power mirrors, dome light , trunk release and the remote would not work. I discovered also I had no brake lights. The fuse inside the car was not blow but the break light fuse under the hood was. when I change it everything else started working again.
DaveK
Jan 16, 2014 08:16 PM
sause
Nov 23, 2010 09:11 PM
datsun40146
May 26, 2010 05:08 PM
tminga
Jan 13, 2007 01:21 PM
johnw
Mar 1, 2006 08:07 PM
