re crank sensor help 2.5 v6
Old Feb 10, 2011 | 04:53 AM
paulesp's Avatar
Default re crank sensor help 2.5 v6
hi again
Really appreciate the feedback but could you be more specific on finding the crank sensor if possible please - I really am struggling.
Or have you possibly got a picture or description of what it looks like.
Its on a 2.5 v6 stratus/sebring cabroliet - european model.
More detailed description how to find it the better.
I am finding your forum really good. It as been 6 months since i have had the pleasure of driving the car - the sun is out and really want to get it back on the road.
I have had numerous mechanics look at it and my latest one is still struggling to find it.
Hoping and waiting in anticipation for as much help as i can get.
Old Feb 10, 2011 | 09:47 AM
buy a service manual and read
Old Feb 10, 2011 | 10:59 AM
TNtech's Avatar
Quit starting new threads.........
Old Feb 10, 2011 | 03:44 PM
Get one of these:
http://www.haynes.com/products/productID/103
Chapter 6.
Old Feb 11, 2011 | 03:32 AM
paulesp's Avatar
thanks i made a few mistakes on the thread and did not know how to rectify them so put new threads up. I have a haynes manual on order. When i get to england i will pick it up.
I did buy a service manual on a disc from ebay but it did not work - waste of money then i found another service manual but it is only in german. All i have done is try to make as plain and simple as possible to try to get the answer to one question.
Before i put on the thread i went through every single thread that had been posted. I got alot of help from someone called TN. I tried to contact him direct but was told i was not allowed. I didnt realise i was doing anything wrong by posting a new thread on the same subject. It was the only way i could see to ask a question.
As i have said before thank you for all the help you have given me. The information you have given me on finding the crank sensor i gave straight to the garage and i was asked if i could be a bit more specific hence i asked this site.
yours sincerely
Old Feb 12, 2011 | 12:20 PM
TNtech's Avatar
Back side of engine compartment......Mounted to the transmission bellhousing with a single 10MM head bolt. It has a pigtail about 8" long and a 3 wire plug. Remove the air cleaner and aim a flashlight down in there and it will bite you.
If this is a COUPE-2 door.. (MITSUBISHI BUILT) then the crank sensor will be inside the timing cover. You will see a wire running through the cover. It's mounted to the front of the block. NO, you do not have to remove the timing belt...there's room to get it out.
ihatemychrysler
Aug 20, 2011 11:15 PM
paulesp
Feb 9, 2011 07:03 PM
holdthewind
Cirrus & Breeze
Aug 25, 2009 05:42 PM
speedthrills01
Jan 20, 2009 04:22 AM
trogg
Dec 27, 2008 10:44 AM
