Town&Country - start problems
Old Feb 9, 2011 | 12:35 PM
vasf_20's Avatar
Default Town&Country - start problems
Hi forum,
I have a Chrysler from type Town&Country 1996. In the morning I have to turn many times the key until the engine starts up. It's possible to listen the "click" from the starter but that's it. The motor will not turn on. I've changed already the starter relay but the problem keeps going.
Like I told just in the morning I see this problem. Once the motor is started during the day this problem seems disappeared.
Does somebody has got the same or knows may be what could be the fault?
Many thanks.
vasf
Old Feb 9, 2011 | 04:00 PM
Djinn-n-Tonic's Avatar
That is an expensive proposition......I could hhave that same symptom on any car I pick out of a hat, and the solution could be drastically different .
Check the cable that runs to the starter for corrosion damage, The ground cable from battery to block, and if all connections are clean and tight , remove the starter for bench testing.
Old Feb 10, 2011 | 06:58 AM
vasf_20's Avatar
Hi Djinn-n-Tonic,
thanks for replay. The following days I will try your points and will let you know.
Best regards,
vasf
cn_xm
Nov 6, 2012 08:05 PM
jdog77
Jan 4, 2011 04:10 PM
yukong
Nov 10, 2010 02:30 PM
jdmac
Aug 13, 2010 09:23 AM
Lesley1020
Feb 9, 2009 10:31 AM
