UConnect pairing maximum problem
Have 2007 Pacifica with UConnect factory installed. Has worked well but recently lost connectivity to all phones paired. Tried to pair phone and all steps went well until end of process and then system said "maximum phones paired, paring failed". When I try to "delete a phone" it says "no phones paired". When I do "list paired phones" it says "no phones paired". So the problem is it says that it cannot pair another phone due to maximal phones paired but I cannot delete any paired phones since it doesn't list any paired phones. This is an infinite loop that I cannot seem to break.:eek:
Any suggestions or help would be most appreciated. I tried the ignition, door open, dance a jig etc to try to reset the system-no help. I have not yet tried to pull fuses to the system. It looks like there are multiple fuses to the hands free system and I am hesitant to pull them since the rest of the audio system works well (DVD, Nav etc). Also I saw some advice saying to disconnect neg terminal of battery-again seems like a drastic stem that may have other negative side effects. I have seached these and other forums and have not found anyone with this particular problem (which surprised me). Thanks in advance for help |
Hi I have the exact same problem. I have a 2006 pacifica and its driving me crazy. Tried pulling fuses but still nothing. Any help would be great.
Uconnect Pairing Maximum Problem
I purchased a used 2006 Pacifica 6 months ago which is having the same problems as listed in thread. Initially it worked fine, but now it is not working.
"Tried to pair phone and all steps went well until end of process and then system said "maximum phones paired, paring failed". When I try to "delete a phone" it says "no phones paired". When I do "list paired phones" it says "no phones paired". So the problem is it says that it cannot pair another phone due to maximal phones paired but I cannot delete any paired phones since it doesn't list any paired phones. This is an infinite loop that I cannot seem to break." Has anyone found a resolution to this issue? Any help would be greatly appreciated. Sincerely, Steve |
Originally Posted by sbelarmino
(Post 93023)
"Tried to pair phone and all steps went well until end of process and then system said "maximum phones paired, paring failed". When I try to "delete a phone" it says "no phones paired". When I do "list paired phones" it says "no phones paired". So the problem is it says that it cannot pair another phone due to maximal phones paired but I cannot delete any paired phones since it doesn't list any paired phones. This is an infinite loop that I cannot seem to break." Has anyone found a resolution to this issue? Any help would be greatly appreciated. Sincerely, Steve also there's mention of pulling the glove box out and unplugging the harness thatss plugged into the HFM but that's a pain. I'd do the battery first. |
OK, thanks I will give this try next Monday 12/28 and post the results. Is there another link that gives more information on unplugging the HFM harness in case I have to take the next step?
Thank you, Steve B |
I checked with the Chrysler dealership and all they have to suggest is disconnecting the battery for 1/2, but nothing substantial to suggest. I have done this but problems still persist. I am still at a loss so unfortunately I have no other option at this point than to live with this not working. If I even get a resolution, I will be sure to post.
Same problem here and tried disconnecting the battery, but it didn't resolve the problem. Any other suggestions?
I found a TSB that might address this UConnect concern. It might be worth bringing this to your dealership's attention.
TSB NUMBER: 08-013-05 REV. A GROUP: Electrical DATE: October 1, 2005 SUBJECT: UConnect Hands Free Phone Inoperative OVERVIEW: This bulletin directs the technician to the appropriate diagnostic path by vehicle line. MODELS: 2005 - 2006 (CS) Pacifica 2005 - 2006 (DR/DH) Ram Truck/Ram Truck HD 2005 - 2006 (HB) Durango 2005 - 2006 (KJ) Liberty 2005 - 2006 (LX) 300/Magnum/Charger 2005 - 2006 (ND) Dakota 2005 - 2006 (PT) PT Cruiser 2005 - 2006 (RS) Town & Country/Caravan 2005 - 2006 (WK) Grand Cherokee NOTE: This bulletin applies to vehicles equipped with UConnect™ Hands Free Communications (sales code RSP). **DISCUSSION: NOTE: Verify that service bulletin 08-049-05 has been performed (where applicable) before proceeding further with this bulletin. NOTE: On CS vehicles with a 05091004AL UConnect Hands Free Module, the scan tool may display a $21 - Bus Busy DTC. This DTC is erroneous and should be ignored. |
They said that my car is not part of that service bulletin
Could you PM me your VIN so that I can look through additional resources to see if I can find anything else that may be useful for you?
| All times are GMT -5. The time now is 01:03 AM. |
