What could cause an intermittent starting problem?
Old Jun 30, 2008 | 10:30 PM
1baddturbo's Avatar
Default What could cause an intermittent starting problem?
I got a 99 concorde with a 3.2L V6, with 85,000 miles, it just stalled on my without any warning, then 2-days later, it fires right up as if nothing was wrong. Its a no crank situation, battery & plugs are good,with no DTC's or other warning lights. Now i cant get it to act up, im afraid to drive it & have it stall on me again.
If you could help me at all, or have any input at all its welcome.
Thanks!
Old Jul 1, 2008 | 05:08 PM
RobS's Avatar
Default RE: What could cause an intermittent starting problem?
When you attempt to start it and it wont, does it crank, does it turn at all, does giving it gas effect it, or do you get nothing at all, do the dash lights light up. Does temperature of the vehicle make a difference, hot or cold, any recent work done to it.
Old Jul 1, 2008 | 10:03 PM
1baddturbo's Avatar
No crank no nothing. Dash lights are on. I turn the key no crank or clicking of anything. The AC just got recharged last week, but i know the tech that did it & stood by him while he did it. When it stalled it happened on a rather warm day. i let the car run for awhile & tried to get it to act up & i cant. I
I tried swapping the ASD relay with others while it didnt start, that did nothing. Also,i tested to see if the fuse box was getting power & it was, just the 20-amp ignition fuse wasnt getting power with the key on engine off.
Hope this helps
Thanks!
jwbohrer
Oct 10, 2014 04:39 PM
THEBUS
Jan 27, 2014 01:23 PM
Gasguzziler
Nov 26, 2012 12:39 AM
dcraig10004
Aug 23, 2010 08:47 PM
BIGCJ
Cirrus & Breeze
20
May 27, 2010 05:24 AM
