won't start
2001 sebring conv. keeps blowing 20 amp buss fuse under hood causing a no start, the fuse reads fuel pump/ignition. Anyone have this problem or any advice would be appreciated.
RE: won't start
Which fuse is that? They have numbers. We might be able to narrow this down a bit.
RE: won't start
You could try isolating the fuel pump from the system by unplugging it and seeing if the fuse still blows. If not, I guess you found the culprit. If so, plug it back in and check some other wiring connections etc on the ignition switch circuit.
I think there is a wiring diagram available for your car at autozone.com |
