won't start
Old Dec 3, 2008 | 06:17 PM
msc's Avatar
msc
Default won't start
2001 sebring conv. keeps blowing 20 amp buss fuse under hood causing a no start, the fuse reads fuel pump/ignition. Anyone have this problem or any advice would be appreciated.
Old Dec 4, 2008 | 03:53 PM
Default RE: won't start
Which fuse is that? They have numbers. We might be able to narrow this down a bit.
Old Dec 6, 2008 | 06:04 PM
irdaneel's Avatar
You could try isolating the fuel pump from the system by unplugging it and seeing if the fuse still blows. If not, I guess you found the culprit. If so, plug it back in and check some other wiring connections etc on the ignition switch circuit.
I think there is a wiring diagram available for your car at autozone.com
2005Cruiser
Aug 20, 2018 08:46 PM
skatetrainer
May 12, 2014 08:42 AM
jbda
Cirrus & Breeze
Apr 1, 2013 11:09 AM
laura
Apr 11, 2010 08:48 PM
chris banks
Mar 9, 2006 06:30 PM
