Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
Cold Air Intake
Old Dec 28, 2012 | 01:04 PM
tylersheehy's Avatar
Default Cold Air Intake
This is sort of interior, under hood. I didnt find a performance section but here goes nothing. If you want a cold air intake, look no further. got any questions, let me know!
Okay guys, I made a CAI/RAI for my 2.7 Sebring. Ill post pics and how-to below. It doesnt add HP much(not that I can tell but its only been dyno'd before install). It does however add throttle response along with a lounder exhaust that has a bubble/growl to it. Its a nice tone that fits the car!
Now lets get into this thing!
--Parts I Used(O'Reilly Part Numbers)
1. Spectre Air Filter(9132 SPT)
2. Spectre Air Cleaner Tube Coupler/Reducer(8871 SPT)
3. Spectre Hose Clamp/Bolt Clamp(8703 SPT)
4. Spectre Air Intake Mounting Bracket(8701 SPT)
5. Exhaust Connecting Adapter 3" ID to 3" OD(548581 ROL)
First, Get that old ribbed filter box off. There is one screw on top that you have to take off and there are posts that it attaches to on the bottom. There are 2 clips securing the tube in the back of the box as well. Push the tabs towards the tube and pull the tube out of the box. Slide the filter off the tube and into the box. When this is done, the only thing securing the box will be the 2 posts circled in blue. Pull the box straight up and wiggle it slightly. With a little force, it will come out.
Circled in red there, is the IAT (Intake Air Temperature) sensor, I believe. It may be the MAF (Mass Air Flow) sensor, but either way, it's gonna have to come out. Gently pull the entire sensor straight up and out of the rubber tube. I also got some Mass Air Flow Sensor Cleaner and cleaned it while this was off, it was pretty nasty. Do not disconnect it, do not wiggle it. If you break it, it might be a little costly to replace. Just pull the entire sensor gently out. After you get that out, loosen the tube from the throttle body with a flat screwdriver on the clamp that it is connected with.
Next, disconnect this rubber hose from the tube as shown in red. It should just pull right off. Pull the tube out of the engine bay, disconnecting it from the throttle body. This will make it easier to connect the filter.
I used the 3"-3" connector piece(Green). It is TOUGH to get on, but with some muscle and effort, you can get it attached. I heated it up under hot/warm water for about 5 minutes. Make sure you take some 80 grit sandpaper or something to dull out the lip of the exhaust piece(Blue) or it will scar the adapter. It will still be tricky after heating up and might take another hand but it will go on. After I got it on the exhaust piece I went back to warmed it up again and slipped it onto the intake tube and clamped it down there with the clamps(Red) it came with. Getting it onto the intake tube will be the hardest part of this! Make sure your clamps are strong.
Now for the filter. the exhaust piece slipped right into the filter, not nearly as tricky as getting the adapter onto the tube. I had an extra hose clamp laying around and you will need that to clamp it down. Regular and Color pic included.
Now you will need to secure it somehow. I used the special bolt clamp on the exhaust piece and the intake bracket kit to secure it to a bolt on the intake manifold. Im not sure how to put this part into words except put the bolt clamp on the exhaust and follow the picture to get the bracket kit to match. it will take some adjusting and if I remember correctly you will have to take some of the threaded pieces and fit them into other adapters and things.
After you bolt it down, put the IAT sensor in, I found that if you start one side slightly then push it will go on*I am NOT responsible for broken sensors or any damages that may have occured. I have not had any problems and you should not either.* Then clamp the intake tube back to the throttle body, re-attach the rubber hose to the intake boot. Tighten up the bracket and fire it up for a test run. It should look like this if everything went smooth!
Old Jan 9, 2013 | 09:59 PM
Joseph Ayers's Avatar
I am from California, would this be legal in this state? I know most car modifications aren't in California.
Old Jan 31, 2013 | 10:50 PM
Not sure man. I would assume so because there is still a filter and a MAF/IAT sensor on there. just got rid of the box...If a CAI is legal this is DEFIANTLY legal.
Old Aug 6, 2014 | 03:38 PM
07300SRT8's Avatar
Anyone in the Tampa bay Area in need of a K&N cold air intake for a 3.5 v6 300M? Follow this link..
Chrysler 300m Dodge Intrepid cold air induction intake K&N cai
Old Aug 8, 2014 | 08:51 AM
mulletsquirrel's Avatar
Looks like you did a really good job, Tyler!
How much did it cost for all the parts?
How long did you spend researching + installing this?
Have you gotten any check engine lights after installing this?
Old Mar 23, 2017 | 03:52 PM
300Addict's Avatar
Default Thanks for the tutorial!
Fantastic photos. Thanks for the tutorial!
Old Apr 20, 2017 | 10:07 PM
Funny how those aftermarket "cold air intakes" wind up sucking air from right behind the radiator whereas the factory intake is down by the wheel well. But then, their air filter is noticeably smaller than the factory air filter which means that it's either more restricted air flow (less area to draw through) or more porous, which is to say larger dirt particles can get through.
But they look really snazzy.
choskovec
Mar 23, 2017 03:53 PM
justawop
Apr 14, 2009 07:14 PM
onebad300C
Feb 21, 2007 01:27 AM
advans
Dec 26, 2006 10:45 PM
fdfever
Dec 6, 2006 07:35 PM
