Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
windows stopped working
Old Dec 22, 2011 | 01:26 PM
discostu's Avatar
Default windows stopped working
Ok, I'm trying to figure out if I'm even on the right forum, but whatever. All my windows in my 2004 Jeep Cherokee just stopped working. I assumed it was a problem with a fuse, but none of the fuses indicated windows. Are there fuses somewhere else? What's the problem here! Please help me!
Old Dec 22, 2011 | 02:39 PM
will they work from a different switch not just the driver side one? there is not a fuse for the windows
Old Dec 22, 2011 | 04:28 PM
discostu's Avatar
All the windows will not work. And it all happened at the same time.
Also, I'm not sure if this is related, but all the interior lights won't turn off when I start the car. I have to turn the **** on the left that turns all the dome lights off when I am driving...and this turns them off all the time. So when I open the door to get out of the car, they won't turn on now. I can turn them on, but I have to manually turn them off by turning the ****...they won't shut off by themselves. I only bring this up because this problem happened at the same time too.
Old Dec 22, 2011 | 11:23 PM
u have a broken ground wire in the driver side door jam wire harness
Old Dec 23, 2011 | 10:35 AM
discostu's Avatar
well that sounds interesting...Is this something I would be able to fix by myself? Or am I going to need to take it somewhere? Will it be expensive? Do you think that will fix the windows and dome lights? Any info you can give would be great. Thanks for your help, I really appreciate it.
Old Dec 23, 2011 | 03:51 PM
i have no idea what u can or can not repair if u can fix a broken wire then go ahead if not visit a shop and get a quote.
Old Sep 28, 2012 | 04:55 AM
cadelee548's Avatar
Thanks for sharing such a vital information, actually I am looking for information regarding. Now this thread definitely help me a lot.
___________
UG Tool Blog -
spencerg
Sep 1, 2013 03:34 PM
Bigripper1
Dec 4, 2007 12:55 PM
orangelover1973
Dec 23, 2006 03:25 AM
brad
Nov 21, 2006 06:40 PM
94 Octane
Nov 10, 2005 11:39 AM
