2001 SEBRING conv no spark
Hi I own two 2001 conv just bought 2nd one and pulled motor and put in one from wrecker now I have no spark my other one needs water pump but runs so I borrowed crank and cam sensor from it ,still no spark ....any suggestions ...I'm a Chrysler rookie but wrenched on personal vechiles my whole life trained marine mechanic but this newr ****e baffles me sometimes??why on earth didn't Chrysler just stick with internal combustion ??why add internal waterpump ,guess I'll never know!!!
I did break crank sensor on engine INSTALL goin out to car now to check harness,,maybe I should just swap harness with other one and see what happens ,,also do a alarm reset cuz battery went dead ,any more suggestions
what engine did u install? what year?
I believe it was outta a 2002 I have spark now...zero compression now on all 6..is it possible to bend a valve in all cylinders turning engine over by hand and by starter??damm ...
Thanx Kevin ...also I didn't have a puller for harmonic but upper marks lined up..so I thought bottom was OK..I measyred distance from piston top to head on other block and rotated that one to same and links matched marks...and finished assembly
if you have no compression yeah bent vales
Would it bend one or more valves per cylinder just by cranking over by hand and with starter??thanks for your replies I do appreciate your input thanx mark
yeah either one it will
Ohh man ..thanx again ...soo I have a spare engine I guess I could just swap heads??what do u think ?cams and all??just reset chaain and hope for the best??that seems my cheapest fix (my time)
Or pop valves out and replace bent ones ..so u say they All could possibly be bent??
