2004 Sebring power window problems
Hi everyone,
I have a 2004 Sebring and when I bought it a few weeks ago, only the driver's side windows would work. Changed the motor and the main switch on the driver's door but still didn't fix it. Found 3 wires that were broken inside the boot on the driver's door. Rewired them and now all the windows work except the back passenger one. Breaker is fine or the others wouldn't work. Checked the wires in the boot on the back door and nothing is broken or frayed. Took the back panel off and nothing is wrong. Is there a possibility that the switch is gone on the back passenger door? Shouldn't it work from the main switch on the driver's door? Anyone have any suggestions? Thanks |
Did you check to see that the motor on the rear door is OK?? It won't work from the drivers door if the motor is not good. Check for proper voltage at the motor if you have a meter. If voltage is OK replace the door motor.
I was told that there wasn't a motor in the back door. That the main motor in the driver's side was the only motor and it ran all 4 windows. Thanks for your reply grbullets.
Originally Posted by Carolyn
(Post 105953)
