2004 Sebring power window problems
Old May 14, 2018 | 02:24 PM
Carolyn's Avatar
Question 2004 Sebring power window problems
Hi everyone,
I have a 2004 Sebring and when I bought it a few weeks ago, only the driver's side windows would work. Changed the motor and the main switch on the driver's door but still didn't fix it. Found 3 wires that were broken inside the boot on the driver's door. Rewired them and now all the windows work except the back passenger one. Breaker is fine or the others wouldn't work. Checked the wires in the boot on the back door and nothing is broken or frayed. Took the back panel off and nothing is wrong. Is there a possibility that the switch is gone on the back passenger door? Shouldn't it work from the main switch on the driver's door? Anyone have any suggestions?
Old May 20, 2018 | 05:31 PM
grbullets's Avatar
Did you check to see that the motor on the rear door is OK?? It won't work from the drivers door if the motor is not good. Check for proper voltage at the motor if you have a meter. If voltage is OK replace the door motor.
Old May 21, 2018 | 07:17 AM
Carolyn's Avatar
I was told that there wasn't a motor in the back door. That the main motor in the driver's side was the only motor and it ran all 4 windows. Thanks for your reply grbullets.
Old May 22, 2018 | 04:04 PM
grbullets's Avatar
I'm pretty sure that's impossible. How could the window possibly go up and down without a motor in the door? There has to be a motor there to operate the mechanism that brings the window up and down. There's one is every door. If the one in the driver door went bad it's very likely the one in the door that doesn't work is bad as well.
Joey-D
Jan 6, 2019 12:34 AM
07pacificaNH
Mar 8, 2013 08:08 PM
pauliwalnutz
Mar 3, 2009 01:44 PM
LT102
Jan 27, 2008 06:45 PM
wmcleod
Feb 1, 2006 10:30 PM
