2005 pt cruiser won't start
Old Jul 11, 2016 | 08:27 PM
Jo Close's Avatar
Default 2005 pt cruiser won't start
So I am at a loss. My car won't start. I turn the key and there is nothing. The dash lights work but nothing else. I have had the battery and starter tested, they were both good. I've replaced the ignition acuator and the ignition switch. I've checked the fuses and replaced the one that was bad. Any suggestions would be greatly appreciated.
Old Jul 12, 2016 | 11:18 AM
Starter relay?
Actually, there are probably over a hundred different parts that must work to start a car. A bad electrical connection, failed relay, broken wire, failed switch, random short, corrosion in a connection and many other things can be responsible. Somebody using logic, patience and the right tools is going to have to go through the various systems one by one in a logical fashion and hunt down the problem. Beware of somebody wanting to throw random, expensive parts at the car in the hope of chancing on a solution.
Old Jul 13, 2016 | 08:30 AM
Jo Close's Avatar
I tested the starter relay and it works. Does anyone have a wiring diagram for 2005 pt cruiser touring edition nonturbo. Also, I should mention that I had someone put in a new starter a couple of months ago and I found out that he didn't have it tightened down all the way. I had it tested before I tightened it back up.
Old Aug 20, 2018 | 08:57 PM
helpme1's Avatar
Thats my exzact freaking problem and have reoplaced battery starter crankshaft sensor and ignition thing same as the one u did
and i can not figure it out and none of the 3 ppl i hav paid
RookieDIY
Jan 21, 2020 02:25 AM
helpme1
Aug 22, 2019 03:07 PM
mgreenb561
Feb 28, 2018 06:12 AM
Petereflynn73
Sep 25, 2011 11:16 AM
seanclark
Sep 1, 2008 03:22 PM
