Check engine light on
Old May 12, 2014 | 09:17 PM
Polo's Avatar
Default Check engine light on
I have a 07 Chrysler Sebring 2.4 sedan I went to autozone to check my car out for any codes when they scan my car i had three code telling me my 02 sensor are bad sensor 1 bank 1 up stream so I change both sensor they it told me my cat was bad so I change thAt as well also change camshaft sensor and the check engine light is still on what u think it could be
Old May 13, 2014 | 01:39 AM
are the codes the same? what are the codes? and Not all the time just because a code pops up does not mean that its for that item. If it were all that simple I would be out of a job and an Associate degree and 18 years of training is worthless.
Old May 13, 2014 | 10:52 AM
Polo's Avatar
Default Codes
The codes are p141 heated sensor 1 bank 1
Old May 13, 2014 | 05:07 PM
Polo's Avatar
Default Codes
I went to auto zone again to scan it again and the code that came up p0038 and p0032 02 sensor when I change it three times already
Old May 14, 2014 | 10:19 AM
robby-britton's Avatar
Codes for lambda sensors rarely mean the sensor is faulty. It's usually an air leak or a problem further up the air system like an air flow meter or something along those lines
Old May 14, 2014 | 11:02 AM
U used BOSH o2 sensor huh?
Old May 15, 2014 | 06:58 AM
Polo's Avatar
Default Codes
Yea i use bosh 02 sensor
Old May 15, 2014 | 07:02 AM
Polo's Avatar
What u think I should do to fix it tired of seeing the check engine light on
Old May 15, 2014 | 11:46 AM
Bosh are not compatible with chrysler U will need an NTK or DENSO o2 sensor take them back.
Old May 18, 2014 | 06:59 PM
Polo's Avatar
Default Codes
Denso should fix the problem should I change both sensors or just the upstream
