2005 transmission issue!
An intermittent issue with automatic transmission. Over the last few years on three to four occasions when coming to a stop sign car does not downshift, then will not shift into next gear. When this happens, if I turn car off, then restart problem goes away . After this happened three to four times, car went into limp mode, other times no engine light. Dealer says they checked things, but couldn’t find a problem, and did hard reset. After 120 miles symptom started again !! Please help solve this issue !! Thanks John
Originally Posted by tromjf60
(Post 110098)
2005 Crossfire
My thread was regarding my 2005 Crossfire
2005 Crossfire trans issue
Mileage is 34000
2005 Crossfire
The trouble code is P0715. Code only appears after three to four issues with downshifting. Turning key off then on and problem goes away until next time.After a number of times, car goes into limp mode
(Post 110104)
The trans oil pan and valve body need to be removed to get at this part, if you're not a DIY type person, you may want to relay this info to your shop or dealer. |
