Other Any other Chrysler within.
Cordoba Questions
Old Mar 8, 2014 | 07:14 PM
Sloth's Avatar
Lightbulb Cordoba Questions
So, I just bought a Cordoba from a friend of mine, and it is in pretty rough shape. Here are two of the first questions I have:
First question: I want to delete the air filter box, but I'm cautious because there are a couple of vacuum lines coming out of it, the EGR line, and some wire harnesses running to some kind of electrical box of the right side of it. Can I delete the filter box without worrying about these? If not, how would I alter them in order to be able to delete the filter box?
Second question: I want to manually control the choke from inside the cabin, so I am going to run a cable from the choke to a **** in the cabin that I am going to install under the dash. Are there any major things I should know about this car before I attempt this?
Thanks in advance!!
Old Jan 2, 2015 | 09:41 AM
DavidWood's Avatar
This sounds like the Chrysler Lean Burn tech. You will need a new simple manual carb, a new distributor and ignition box. That box with all the wires is the computer. Your carb and distributor won't operate without it. Run a search in this forum regarding Lean Burn and you will see how it is done step by step. I retained mine in my 1989 Fifth. On the "It ain't broke--Don't jack with it." basis.
americandxer
Aug 27, 2021 05:04 PM
hbailey
Other
Oct 30, 2018 03:01 PM
TTA89
Mar 21, 2009 12:05 PM
choust1
Oct 7, 2007 01:44 AM
skatecentury
Nov 25, 2006 01:13 AM
