Where oh where is the brake controller plug
Old 05-14-2018, 03:59 PM
johnlittle01's Avatar
Default Where oh where is the brake controller plug
Hi everyone. I recently bought a nice 2007 Aspen to do some towing with. It appears to have come with the factory tow package though I cant find it in the build sheet. It has all the expected components you would find in the tow package as well as the tow/haul option on the shifter stalk in lieu of the OD off. However I cannot find the brake controller plug anywhere under the dash. Any help with its location would greatly be appreciated. Thanks all.
Old 05-15-2018, 07:58 AM
Rawyzf's Avatar
Traced the wire.....it's on the left side, floor board almost.
Last edited by Rawyzf; 05-15-2018 at 12:57 PM. Reason: Correcting statement / location.
Old 05-15-2018, 08:47 AM
Thanks, but I still cannot find it. I see the controller in your pic and the wire harness but not the factory plug. E trailer shows it on the left side under panel. You can make out the blue plug in the pic. Is it possible that it could have the tow package but not the factory plug for the controller?
Old 05-15-2018, 08:54 AM
Rawyzf's Avatar
Yes.....that is possible. The plug I believe came in the glove box, the person probably tossed it out.
Old 05-15-2018, 10:38 AM
calamity coyote's Avatar
Yes, that blue plug you show in your picture next to the white cover is the brake controller plug. You need the harness that plugs in to it and wires to your controller. The part number for the harness is 56045795AB. When I bought my Aspen a few years ago, the harness was in the rear storage compartment. The section that opens from the floor by the rear hatch. If you don't have this harness, you will need to pick one up.
Here's a link to the part on Amazon for $34.16
Amazon Amazon
Old 05-15-2018, 11:25 AM
Unfortunately that pic is not of my aspen. I got that off the etrailer site showing where the plug should be in my 2007. In my vehicle it is not present. I have the adapter plug from the brake controller but noting to plug it into.
Old 05-15-2018, 12:50 PM
Rawyzf's Avatar
Ok, so I found the plug on the floor almost, left side.
Old 05-15-2018, 01:18 PM
That's where it should be but it's nowhere to be found on mine. I'm going to pull the panels out and see if it has somehow been tucked away amongst all the other wiring.
Old 05-15-2018, 02:08 PM
Rawyzf's Avatar
Sounds like fun!
Old 05-15-2018, 03:41 PM
REBEL59's Avatar
I have an older year and different Chry. model(04 T&C) that came with factory tow package. The harness was in a rear storage bin and was only for light duty trailer lighting to hook into the rear light harness, NOT a brake controller. Maybe they use different specifications of tow packages, since you can't find a brake controller plug for yours? And maybe such harness needs to be installed for use of a brake controller?
Quick Reply: Where oh where is the brake controller plug
